Will this prebuilt PC run dayz on medium to low settings?
that graphcis card should be able to play day z on medium to high settings 1080p around 40 to 50 fps, from my estimates of how well it does on BF4
you should be able to upgrade that graphics card if you purchase a better power supply, 300 wat power supply is pushing it in my opinion. mobo memory upgrade should be fine however. get a 500 wat 80 plus bronze certified power supply.
also for 600 dollars you could prolly piece together a computer that performs better than the one your buying but youwouldn't get windows with it. so i say upgrade the power supply on the prebuilt one if you upgrade the graphics card
