Will this PSU connect to my motherboard and case?
dude7691
241
Hello everybody! I am building my own PC and am not sure if my PSU is compatible with my ATX case and ATX motherboard. The PSU says that it is a 20+4 pin and my motherboard is 24 pin. What exactly does this mean? Do I have to buy a separate 20-pin to 24-pin adapter from the PSU to the motherboard? Anyway, the links are below if it helps. Thanks.
Motherboard: http://www.ebuyer.com/351598-gigabyte-ga-z77-d3h-socket-1155-vga-dvi-hdmi-8-channel-audio-atx-motherboard-ga-z77-d3h
Case: http://www.dabs.com/products/best-value-v8-white-gaming-case-with-usb-3---2-x-12cm-blue-led-fans-9406.html?utm_source=google&utm_medium=ppc%20product%20search&utm_content=Q200&utm_campaign=Components%20and%20Storage%20-%20Cases,%20Cooling%20and%20Power%20-%20
PSU: http://www.amazon.co.uk/Alpine-750W-PSU-120mm-Red/dp/B004ZK317A/ref=sr_1_5?ie=UTF8&qid=1388314578&sr=8-5&keywords=700w+atx+psu
Thanks for the continued support and I really do appreciate this community 🙂
Yes, everything will fit together. But i do not recommend that PSU. It is way too cheap, and won't fit in the longterm. I'd recommond you to take a look at a PSU from a trusted manufacturer. (Corsair etc)
^ This. That power supply is trash.
Power needed here. The list includes the entire system along with headroom for overclocking.
http://www.realhardtechx.com/index_archivos/Page362.htm
Stick with Corsair, Seasonic, PC Power and Cooling, XFX, Silverstone, Enermax, OCZ, Antec or the higher efficiency Rosewill units for quality.
