Will This Rig Be Able to Play Dota 2 at MAX Settings and 2560x1600 Resolution?
CaptainGG
24
I'm looking to buy/build a computer that can run Dota 2 on max graphics settings and 2560x1600 resolution with NO stutters (minimum 60-70FPS at all times). This build looked like it may be able to handle it but I wanted your opinion. Please also suggest a case and suitable power supply if you can.
My budget is <$1000 Canadian in case you want to suggest something else.
MSI Gaming 970 Gaming AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard ($139)
MSI GeForce GTX 960 DirectX 12 GTX 960 GAMING 4G 4GB 128-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support ATX Video Card ($349)
HyperX FURY 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) Desktop Memory Model HX421C14FBK2/8 ($79)
Intel Core i3-4170 3M Haswell Dual-Core 3.7 GHz LGA 1150 54W BX80646I34170 Desktop Processor Intel HD Graphics 4400 ($159)
SEAGATE OEM 1TB BARRACUDA 6GB/S SATA 7200RPM 64MB 3.5IN ($72)
Thanks!!!
