Question will this setup work to convert my LED monitor into a TV?
argonvegell
Commendable
Jun 12, 2017
Not sure if this is the right place to ask this, if it's not, I apologize.
LED Monitor
Digibox provided by cable television provider
RCA to VGA Cable
RCA to Audio Jack Female
Speakers
I'm trying to find the cheapest solution possible to convert my LED Monitor, which is just in my closet collecting dust, into a TV.
Will this setup convert my LED Monitor into a TV? Thanks.
Lutfij
We're going to need more info. Can you pass on the model for your AOC monitor? Are you sure it's an AOC built monitor? We're also going to need the outputs from the set-top box in order to understand if you can hook said monitor to the cable you've parsed as an image.
Btw, by cheap, how cheap are you going?
argonvegell
Commendable
Jun 12, 2017
AOC 2040V
Not sure what you are looking for.
The cheapest I can go, I don't have exact figures.
