Will this system and its components be compatible?
velenjak
Any red flags with this build? "Lemon" parts? Suggestions? Comments? Thank you very much!
NZXT Source 210 ATX Mid-Tower case
Samsung Spinpoint F4 7200 RPM 320 GB
Antec Neo ECO 620C 620W PSU
Samsung 4GB X 4 240pin DDR3 1600
Nvidia Geforce 9600 GT
MSI Z77A-G43 LGA 1155 Z77 SATA
Intel i3-3220 Ivy Bridge 3.3Ghz LGA 1155
also, with this build would you guys recommend I get additional fans?
point taken, my friend gave it to me about a year ago. The only games I play were made at least made 5 years ago (I'm not into new games) - but I do have some graphic intensive programs that I need to use for school... So I'm guessing I should just buy a new graphics card yes? Or will this 9600 be able to suffice.
Given, I am using a 128mb dedicated card right now (ancient I know!) It does everything I need it to do, but it is very slow and 'notchy' with the academic program. I don't need a top of the line GPU... can you make a recommendation for me?
If you already have it its certainly fine to give it a try, and it may work for your needs. Its still better than the integrated gpu on Intel CPUs. Just thought it was a list of parts you were buying and threw me lol.
You don't need a z77 board since you won't overclock with that CPU, but its fine to use one. The PSU is more than needed, 500W would be plenty but again it would work fine
