Will this system of airflow work with my case and components?
Unpolarize
25
I'm using the Hyper 212 Evo with my case and I was wondering if this system of airflow will work with it? I'm doing exhaust fans on the top because there is absolutely no air filtration on the top to keep dust from falling inside the case and because I want maximum airflow because my video card will generate quite a bit of heat:
My only problem with this design is this - I'm afraid the top front exhaust may take away airflow from the CPU cooler, and I'm afraid the number of exhaust fans I have will generate negative airflow inside my case because the bottom fan, front fan, and side fan air flow may be blocked by the Graphics cards/Drive Bay, which will result in negative air pressure in the top portion of the case. If you have any other suggestions on what I can possibly do, here is a diagram of all the different case fans I can use.
Note: I will not use the pivot fan because it will interfere with my video card. Also, the fans and descriptions highlighted in red are the fans that came installed with the case.
Thanks, I'm just unsure on what to do. I don't want to take away airflow to my CPU Cooler and I don't want to create negative air pressure in the top when all my intake is based at the bottom.
