Question Will this system work fine
Jun 26, 2022
7
https://uk.pcpartpicker.com/list/4hHrmr
got this build from the forum and i have made a couple of changes, just wanted to double check that everything will be compatible and there are no changes that need to be made. Also if there is any way of me saving money without losing performance then that would also be greatly appreciated, thanks.
Eximo
Ambassador
M.2 NVMe drive rather than SATA. Cost difference is minimal for much greater speed.
I would go for a 650W PSU with a little higher rating. If the budget is an issue, drop down to the i5-12400, the 12500 only gains you a faster iGPU really.
PCPartPicker Part List
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor (£182.00 @ Amazon UK)
CPU Cooler: Deepcool GAMMAXX 400 V2 64.5 CFM CPU Cooler (£29.71 @ Amazon UK)
Motherboard: Asus PRIME B660M-A WIFI D4 Micro ATX LGA1700 Motherboard (£138.97 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory (£59.99 @ Amazon UK)
Storage: Western Digital Black SN750 SE 1 TB M.2-2280 NVME Solid State Drive (£89.99 @ Amazon UK)
Video Card: Asus GeForce RTX 3060 Ti LHR 8 GB DUAL OC V2 Video Card (£509.49 @ Amazon UK)
Case: Corsair 4000D Airflow ATX Mid Tower Case (£89.00 @ Computer Orbit)
Power Supply: Corsair RM (2021) 650 W 80+ Gold Certified Fully Modular ATX Power Supply (£89.99 @ Amazon UK)
Total: £1189.14
Generated by PCPartPicker 2022-06-30 21:37 BST+0100
Jun 26, 2022
7
Total: £1189.14
would it be beneficial to go for the 12400f instead of the 12400?
punkncat
Ambassador
I cannot recommend using a CPU without onboard graphics, where possible. If (in the future) you have a video issue it allows an easy path for troubleshooting that is worth FAR more than the ~$30 price difference. Also, if you ever get into video editing or streaming it has benefits there as well.
Reactions: Phaaze88
