R RhinoTV Reputable Mar 2, 2017 331 2 4,785 Jul 5, 2018 #1 Hello, looking at getting this system. Will it work right out of the box ? Thanks https://imgur.com/a/yxXJGmR
Solution Rogue Leader Jul 5, 2018 RhinoTV : going to use a nzxt kraken x62 Rogue Leader : What are you using to cool the processor? Ok sounds like a good plan then. For that ram to work at full speed you need to turn on XMP in the BIOS.
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,378 3,242 116,640 Jul 5, 2018 #2 RhinoTV : Hello, looking at getting this system. Will it work right out of the box ? Thanks https://imgur.com/a/yxXJGmR Those 3 parts will work together yes, but you need a lot more than just a CPU, motherboard, and Ram. Upvote 0 Downvote
Corwin65 Illustrious Nov 2, 2015 3,590 153 37,090 Jul 5, 2018 #3 As long as you have a compatible case, psu, SSD/HDD CPU cooler and OS to install then yes. Upvote 0 Downvote
R RhinoTV Reputable Mar 2, 2017 331 2 4,785 Jul 5, 2018 #4 sorry forgot to add that ahaha. Im just upgrading my cpu mobo and ram Rogue Leader : RhinoTV : Hello, looking at getting this system. Will it work right out of the box ? Thanks https://imgur.com/a/yxXJGmR Those 3 parts will work together yes, but you need a lot more than just a CPU, motherboard, and Ram. Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,378 3,242 116,640 Jul 5, 2018 #5 What are you using to cool the processor? Upvote 0 Downvote
R RhinoTV Reputable Mar 2, 2017 331 2 4,785 Jul 5, 2018 #6 going to use a nzxt kraken x62 Rogue Leader : What are you using to cool the processor? Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,378 3,242 116,640 Jul 5, 2018 Solution #7 RhinoTV : going to use a nzxt kraken x62 Rogue Leader : What are you using to cool the processor? Ok sounds like a good plan then. For that ram to work at full speed you need to turn on XMP in the BIOS. Upvote 0 Downvote Solution
