[SOLVED] Will this system work?
Aug 4, 2019
Hello everyone.I am new to building a pc.I am going to use it for playing games and programming.(FarCry , COD, GTA V).It should last 4-5 years.Will this system work?What do you recommend?Any help would be appreciated.
AMD Ryzen 5 3600 3,6GHz 35MB Cache Socket AM4 Processor
MSI B450M Gaming PLUS AM4 AMD Ryzen DDR4 Socket 3466+MHz (O.C.) USB 3.1 Motherboard
Corsair Vengeance LPX 16GB(2x8GB) 3000MHz DDR4 Ram (CMK16GX4M2D3000C16
MSI Nvidia GeForce GTX 1660 Ti Ventus XS 6G OC 6GB 192Bit GDDR6 (DX12) PCI-E 3.0 Graphics Card(GeForce GTX 1660 Ti VENTUS XS 6G OC)
Samsung 860 Evo 500GB 560MB-520MB/s Sata3 2.5" SSD (MZ-76E500BW)
Toshiba P300 High Performance 3.5" Sata 3.0 1TB HDD (HDWD110UZSVA)
SilverStone Strider 80Plus 500W Power Source (12V , 38A Current)(SST-ST50F-ES230)
The Paladin
Glorious
Herald
well I plugged your system in to https://pcpartpicker.com/ and something came up as a warning about your motherboard compatibility and your cpu, you can see the listing at https://pcpartpicker.com/list/8QvNXP
but here is the message: Warning!: Some AMD B450 chipset motherboards may need a BIOS update prior to using Zen 2 CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.
Reactions: TheMagnificent
The Paladin
Glorious
Herald
