Question Will this usb power a. Fan
I'm also under the impression 5V is not enough to start a 12V motor. 3-pin fans stop spinning long before you get near the minimum of whatever range of control you can use. In my experience the cut-off was typically 50%, though I don't know what the voltage/% relationship is.
