Will this wifi adapter work?
Shaun_42
19
I am not familiar with these products, that's why I'm here. I am building a pc for the first time and I am wondering if this usb wifi adapter(https://www.thewarehouse.co.nz/p/tp-link-wireless-n-300-mbps-usb-adapter-tl-wn821n-white/R1560825.html?source=igodigital) will work/Be compatible with everything? Can you plug it in and use it easily? I am wondering as it would be a struggle to get a wired connection yet it is possible if necessary.
In answer to your question, yes! The USB wireless dongles are surprisingly easy to set up. Simply plug the dongle in and let it install any software. Then follow set up instructions.
For online gaming, i would encourage the use of a wired connection, but general internet usage and watching films etc it will work fine. Hard wiring is always the preferred method of connection, but it ultimately depends on your type of usage!
Hope this helps.
Hope this helps.
