[SOLVED] Will this work?(1080p gaming with good frame rates?)
Sep 5, 2020
Will this budget build work or it needs change? (not changing the budget too much)
AMD Ryzen 7 2700 Desktop Processor
GIGABYTE B450M DS3H Motherboard
GALAX GeForce GTX 1660 Super
A-DATA XPG GAMMIX S11 Pro 256GB PCIe Gen3x4 M.2 2280 Gaming SSD
Zebronics Zeb-Cronus Premium Gaming Cabinet
XPG ADATA GAMMIX D30 DDR4 8GB 3200MHz RAM
Artis 500 Watt Super Silent Gaming PC SMPS/Power Supply Unit
https://gpu.userbenchmark.com/Nvidia-GTX-1660S-Super/Rating/4056
Not guaranteed but this should give you a reasonable ideal of the frame rate that you can get. At 1080 on a normal monitor it will do everything you want it to do. Running on a tight budget get a good power supply and have reasonable performance expectations and you will be fine. If you are expecting to fully push a 144hz or 240hz monitor I would shell out the extra 300 bucks and wait for the 3070 but if you do that I would go to at least an 80+gold 750 watt power supply as well.
Will it work? Yes. However, that PSU is of questionable quality. I would suggest a better PSU, like from Seasonic or Corsair, if your budget can accommodate it.
Is your memory 1x8GB or 2x4GB (the second is better for performance)?
The memory is 1x8GB. I thought of getting 2x8GB of those.
And what if I change the power supply to Cooler Master MWE 550W?
Reactions: Blaze007
I dont know what type games u will play but i have same gpu and can play gta5 1080p on ultra high... But u have only 8 gb ram and week psu. Try buy 2x8 ram and if u planing future upgrade buy 650 or 750 psu
Reactions: Blaze007
Yeah maybe I'll wait for sometime now, in India the r5 3600 is approximately $290 right now. Maybe wait for the zen 3 CPUs, or any changes you would want in the above configuration? Thanks
