g1abhi :
smorizio :
missing the cpu cooler...skylake retial cpu now down have heat sinks. also swap out the 520 for the xfx 650 that 30.00 more the xfx units are rebranded seasonic units. using the larger power supply if you ever put in a higher end gpu you wont have to swap out the power supply.
Only unlocked ones come without heat sinks . Rest have cooler bundled.
And 650W is needed only for Radeon GPUs , I have a 650W seasonic and gtx 960 and my consumption goes 190W max. I regret buying too powerful PSU. even if he uses a R9 390 or 980 TI , his consumption will be 380W max.
Don't you love them not including at least a stock CPU HSF with the K series CPU's? I know most enthusiasts get a different cooler anyway, but why not just give the option with a $5-10 price difference? Most people could deal with a stock CPU HSF until they want to OC or get cooler/quieter system and will spend $ on a better CPU HSF.
Yeah most people overpower their systems with bigger PSU's than they need, but I think most people don't realize that most single GPU systems don't use more than 200-300w, unless you have an AMD exclusive higher end system (CPU and GPU).
