Will this work..? I am a bit confused
SIllyskywalker
Commendable
Sep 8, 2016
35
Sorry in advance if this is confusing, but I will try my best to explain my situation.
So I want to completely wipe my HDD so i can install Kali Linux on it. I currently have Windows 8.1 installed on it. So once I completely get rid of Windows 8.1 can I reinstall it (Whenever I want on any machine) using the same product key? I do not have the Windows Installation Disc because windows came pre-installed on my laptop but I have the product key.
I got my product key by opening up powershell and typing this in:
" (Get-WmiObject -query 'select * from SoftwareLicensingService').OA3xOriginalProductKey "
and it gave me the product key.
So since i dont have installation disc can I create my own installation media on a usb as seen here? https://www.microsoft.com/en-us/software-download/windows8
and once I do use my installation tool.... if i input the product key that I got off of powershell than I should have windows 8.1 installed?
Sorry if this is very confusing.
If you have the license key, create your Win 8.1 install from your above link.
Yes, you can reinstall on that same system.
However...Kali Linux is not really meant for a daily use OS.
Security testing, penetration testing, forensics, yes. Daily use? Not so much.
Yeah that is what i am going to use Kali Linux for, Penetration Testing. Thanks :)
Then run it from a DVD or USB stick. Don't wipe out your primary OS (Win 8.1) just to install Kali.
Also what is t he difference between the License Key and the Product Key..? Where can I get the license key?
Different applications call it different things.
The license key is constructed thusly: XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
5 groups of 5 characters and numbers.
The Product ID may be something completely different.
