Will triple slot fit?
maza90210
129
I don't get what triple slot means. Will it use 3 pcie slots? if so will it fit on my p8z77-v lx? I can get a mobo with more slots if required. also will it fit in teh aerocool Xpredator. the graphics card is the Inno3D GeForce GTX 760 iChill HerculeZ 3000.
Thanks in advance
Yes, your card will fit. It will overhang the next two slots on your motherboard. Not a problem unless you have a use for those slots.
For what it is worth, I think graphics cards with such fancy coolers are more for show than go.
I would spend the price premium paid for them on something more productive, like a stronger card in the first place.
I'll probably not use the slots, thanks for the help! Also the cooler is awesome! on guru3d the temps are below 50 degrees celsius which is just crazy low
OH! Thanks that is really helpful!
