Hello,
What happens if the gpu is powered but the other parts are not (mb, cpu,etc— Only the gpu)?
Will it damage the gpu or is there some failsafe that prevents the damage from happening?
I have a mining rig with multiple gpu that uses 2 psu. What happens if the psu that is connected to the motherboard dies and the psu that is connected only to the gpus is not?
Its like giving electricity to something that shouldn't be turned on.
Notes:
I know that there’s a trick to turn off both psus in case one went out but I would like to know the answer
For those wonder why I ask the question:
I live in a place that has multiple power lines with one of the lines capped at 450Watt and the other 1200Watt, so I'm using two psu. I cannot simply modify it because the owner told me to use it as it is.
thank you. sorry for the bad English, I’m using my limited knowledge and google translate
Notes:
