Will two PC monitors work with a Mac Pro?
lili5689
I just bought a Mac Pro processor and I was wandering if I could use 2 PC monitors with it?
What connectors would I need?
Thank you for your help!
Just look around the model and try to find the model number, NOT the serial number. Then type in that model for example: HP 63ks9 into Google. Then find the specs on that monitor and try to find if it says Mac Compatible. The rest is logic..
