Question Will Upgrading CPU reduce stuttering issues after GPU upgrade?
Morgan_5212
8
New to posting so I have followed the guide set out:
Approximate Purchase Date: This month
Budget Range: £250-300
System Usage from Most to Least important: Gaming
Are you buying a monitor: No
Parts to Upgrade: ( Not 100% Sure CPU/mobo/RAM) Corsair 750I is my power supply
Do you need to buy OS: No Unless I change motherboard?
Preferred Website(s) for Parts: Not bothered as long as reliable
Parts Preferences: I’d prefer to just change CPU but if required would change to AMD and move to DDR4
Overclocking: No
SLI or Crossfire: No
Monitor res: 1920x1080
Additional Comments:
And Most Importantly, Why Are You upgrading: I’m more asking what I should upgrade in order to eliminate stuttering in games.
recently upgraded my gpu to the 1660 super and it’s great however I’ve noticed in forza horizon 4 I get the game capped 50fps at max settings however when entering a new area I get some brief stuttering.
I have limited PC knowledge but I believe this is a CPU bottle neck as I noticed the CPU load is 100% while playing, GPU is around 60% and RAM 80%. I understand I probably need more ram however would this fix the stuttering?
I’m looking into upgrading my CPU to a more powerful DDR3 compatible one, but would this keep me gaming in AAA’s for the next say 2 years? Or do I need to make the switch to DDR4 in order to remove stuttering and keep up with requirements of newer titles.
My current build is
ASRock z77 Pro3 Motherboard
i5-3570
MSI 1660 Super
Corsair 750I PSU
8GB DDR3
Any help much appreciated, thanks.
Mrgr74
Commendable
Hi @Morgan_5212
Would strongly advise against putting any $$ into your DDR3 era system unless otherwise necessary.
That being said, you'd notice a boost if you went to 16GB, but would advise you to go with a 16GB kit and not just add another 8GB as there is always the chance for "issues" when mixing RAM.
Here's a listing of the CPU's that your mobo supports.
Your 1660 S is a great GPU.
Your PSU got good marks, so it should be fine.
Amazon should deliver to your area. I'm in the US so not sure what local parts stores you have.
Are your games on an HDD or SSD?
Whats the speed of your RAM?
Have you played around with https://uk.pcpartpicker.com/list/ ? Even if you aren't sure what goes with what, it'll guide you to whats compatible and give you a general idea of prices. Make a system and post the link here. We'll be able to look it over and suggest replacements or give 2 thumbs up.
Reactions: Morgan_5212
R_K
62
You already have i5-3570 ... I think upgrading to current gen would be the better choice with ddr4.
Go with something like Ryzen 3600 cpu and Asus B550 motherboard and Corsair ddr4 8gb x2 16gb.
Morgan_5212
8
Hi @Morgan_5212
Thanks for the reply! My ram is 666Mhz which to my knowledge is pretty slow and my games are on a mix of SSD and HDD, I need some more storage space 100%.
Morgan_5212
8
A wee bit over @ £331 --> https://uk.pcpartpicker.com/list/rYR8WD
A wee bit over @ £306 --> https://uk.pcpartpicker.com/list/vPJkkd
There is a little wiggle room depending on the CPU &/or motherboard you go with. The mobo I used in the above links is the MSI Tomahawk Max, which is an excellent B450 mobo. Possibly even one of the best.
Wow thanks for showing me this! I like the look of going with the Ryzen 5 3600 CPU. If I do pull the trigger and go for the mobo ram and cpu, do you think this will be worth the investment and will keep me comfortably gaming for the next 2/3 years? It certainly looks like great value for that cpu considering I was looking at DDR3 ones for £200+ alone!
Morgan_5212
8
Thank you for the reply! I am thinking it’s time to bite the bullet and move to DDR4. If I make the switch to AMD is there anything to watch out for? Or should I be able to swap the components and fire the machine up again as normal?
Mrgr74
Commendable
Absolutely. You'll be upgrading your 1660S before the 3600 as the 3600 is a beast of a CPU. I have a 2700x and got it when they very 1st came out, so 2 years ago and it's frankly been great. (and still is) My PC is used for about 10% productivity & 90% gaming. The 3600 is even better and at 1/2 the cost (When it came out) DDR4 is quite a bit superior over DDR3 and Ryzens really shine when you pair them with fast RAM and so would advise that you go with a min of DDR4-3200, but if you can afford faster RAM, then by all means do so as it'll give you a little wiggle room later on.
Regardless if you go with an Intel or AMD (Ryzen) based system, run a few benchmarks 1st with your current hardware and then when you install the new hardware, run another benchmark and compare them side by side. (Not that the performance alone won't be evidence enough! lol)
Exciting times are ahead of you & please keep us updated with what you end up going with! :)
Mrgr74
Commendable
You'd be able to port over your PSU, 1660S, Case, Keyboard, Mouse, SSD & HDD. Your current mobo, CPU & RAM isn't compatible with a Ryzen system. (If you go that route) As for your current hardware, save it as a backup or make a PC for the family, a sibling or GF/BF to use. You could try selling it, but unless you're hurting for $$ or £ 's in your case, you'd probably not get much for it. Wouldn't hurt to try though as there is always someone out there with inferior tech that thinks what we want to sell is so much better that what they have & so....
Enjoy!
Morgan_5212
8
Thanks again for all the help! I’ll certainly keep you posted of what upgrades I make when I get round to it!
Morgan_5212
8
Enjoy!
Thanks, I’ve only ever swapped out a couple components so wasn’t sure if there was anything to watch out for. Really appreciate all the advice I wish I had of turned to the forum sooner!
A I7-3770K would be the strongest processor your motherboard supports.
They sell for $120 or so used on ebay in the us.
With a Z77 based motherboard you could overclock it some.
If you are comfortable in buying and selling used, I would give it a go.
If it turns out to not be sufficient, you would get most of your money back reselling it.
Nothing wrong with DDR3, it performs about as well as DDR4.
A latest gen processor is going to also need a new motherboard as well.
Your budget should buy you a i3-10100 processor that is about twice as capable as your 3570 and a B460 based motherboard and a 2 x 8gb ddr4 ram kit.
