Hi there. I want to upgrade my GPU but am worried that if I go out and spend a couple of hundred on the new card it will make no difference to me due to something else in my system being the problem.
The situation is that I play starcraft 2 at 1920x1080 and ultra graphics in 4vs4 games is going below 10fps. I would like to stay above 40 at all times.
My system is:
AMD Phenom II X4 840
4GB corsair 1333Mhz
Bog standard hard drive
Cit PSU 650W
Sapphire vapor x 5770.
ASRock n68c s ucc. mobo
If I upgraded to the 6970, would this solve the problem? Major thing I worry about is the PCI e1.0 which is like a PCIe 2.0 at only 8x. This wont cause a problem will it? Is there something else in the motherboard that is slowing me down? Even if I put the graphics to low, it drops from 60+ to below 20 in a big battle and it's starting to annoy me. Surely the culprit here is the 5770?
Many thanks guys.
My system is:
4GB corsair 1333Mhz
Cit PSU 650W
Many thanks guys.
