Will usb 3.0 work with sata 1.5gbs hard drives
blade5878
I have a desktop with a new motherboard that has the new usb 3.0 inputs and I am using a sata 1.5gbs hard drive. Will I get the same transfer speeds using an older hard drive with the usb 3.0 inputs as I would if I were using a sata2 or sata3 hard drive?
My guess is that considering the current USB 3 controllers perform well below their theoretical limit (I usually get around 70-90MBps), you should not see much difference with SATA 1.5Gbps drives that can usually do sustained transfers around 100MBps.
When Intel integrates USB 3 controllers into its chipsets they will probably get better transfer rates and then you would start to see a difference.
