Information System Reputable Feb 16, 2014 102 0 4,690 Aug 10, 2017 #1 I have done some research but and from my understanding the answer is no. The only thing that will change is one SATA 6.0 Gb/s port is disabled. However I am just confirming that my GPU performance will not be reduced in anyway. here is my build. Thank you kindly for reading.
Solution R R Rdslw Aug 10, 2017 depends on PCIE config, but looking that you use single card, no SLI this should be fine.
R Rdslw Distinguished Aug 1, 2017 1,902 144 21,340 Aug 10, 2017 Solution #2 depends on PCIE config, but looking that you use single card, no SLI this should be fine. Upvote 0 Downvote Solution
