Will using a power line adapter with an ethernet switch limit my speeds?
bobbyjoe01233
23
Hey everyone!
Recently I have been getting high ping spikes on my games. The ping would jump to 500 for about 2 seconds and then drop back to 20-50. The problem is not my connection, as I get about 60/5 internet speeds. Currently, I have a really cheap wifi card and I have considered getting a powerline adapter, as I have one working for my security cameras, and my desktop is in another room than my router (meaning a direct ethernet connection would be hard to do). I was going to buy another powerline adapter, but I'm out of ethernet ports on my router, meaning that I can't plug anything new in. Then, I had this crazy idea.
My powerline adapter is currently in the closet outside of my room. It only outputs one ethernet port. Then, I thought that I could hook up an ethernet switch to the powerline adapter to do a wired connection to my desktop and my security cameras, while saving money on not buying another powerline adapter, but only an ethernet switch. However, I'm concerned that if I do this, it could limit my speeds. My goal is to save money here.
My questions are:
1): Is this a viable option to save money?
2): WIll this slow down my speeds?
3): Is it better to buy a network switch, plug it into my router, and buy another powerline?
4): Should I ditch this plan altogether and buy a good wifi card?
As long as the switch is rated for speeds that will cover your connection speeds you'll be fine. Just get a quality switch. I personally use a TP-Link 8-port switch comnected to my router in anotger room using a 50ft ethernet cable.
Here is a switch that'll work just fine for you and it's on sale.
TP-Link 5 Port Gigabit Ethernet Network Switch | Ethernet Splitter | Sturdy Metal w/Shielded Ports | Life Time Warranty| Plug-and-Play | Traffic Optimization | Unmanaged (TL-SG105) https://www.amazon.com/dp/B00A128S24/ref=cm_sw_r_cp_apa_OxdqBbXCYEBA0
A switch won't degrade your connection. So whatever connectivity you currently get through the adapter will be what you get on your devices.
Assuming you already have a long enough ethernet...
Assuming you already have a long enough ethernet cable to go from the adapter to the location of said devices being plugged in you can totally just use a switch, which will enable you to connect more devices in said room using it.
