[SOLVED] Will Wifi on the motherboard work on startup?
In my builds, ive just used a cheap dongle to initially get online then download the associated driver/s and take the dongle out.
Yes. is on to go supported.
Otherwise you can Auto Update or using Driver provide via CD or respective website of your Motherboard Brand and model for full Optimization on Wifi Performance
Ok, so WiFi on startup IS supported, but it will be better after installing the drivers from the manufacturers website. I will buy a B450 Carbon Pro Max with WiFi.
Yes, I think I will do this as well.
