will zotac gtx 1080 amp extreme (325 mm) fit in my case (armageddon zetatron t9x) 320 mm?
ahmadbagja28
Commendable
Sep 25, 2017
22
Same as title,
I've read some forum that push the gpu inside their case even it's not fit by number of specs of the case.
I have measured my case and it has about little space if I push zotac in.
Does it safe if I put that zotac into my case?
here's my spec of my case:
7 * Expansion Slot
Support up to 320mm Length Graphic Card
Ventilation Holes on 7 PCI Slots
Dimensions 58cm x 27cm x 54cm
Material Chassis PSCC
can it fit into my case?
https://imgur.com/gallery/rFL97
answers will be much appreciated
please help. thanks.
