Williams Defender Power Supply - To rebuild or not to rebu..
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Should I rebuild a Williams Defender Power Supply or should I use a
switcher? Power supply still works. Are the williams power supplies
very reliable if rebuilt?
John
I would just rebuild it. they have always been reliable for me.
especially a defender's.
The ones I have had trouble with are a robotrons, they need a switcher.
Troy,
Baraka <grus_jc@yahoo.com> wrote in message
news:1113075062.937376.116070@z14g2000cwz.googlegroups.com...
> John
I've got two defenders that I needed to replace the power supply on and
went with the the kit from arcade shop. I've been very happy with it
and really like that all I had to do was just plug in the the existing
harness (www.arcadeshop.com/pics/wms-ps.jpg). I left the original
power supply since it still powers some things on the coin door. I
found you still need to run a ground from the new power supply or else
the coin door and control panel will not work.
Troy <troyl@lvcm.com> wrote:
: I would just rebuild it. they have always been reliable for me.
: especially a defender's.
: The ones I have had trouble with are a robotrons, they need a switcher.
What?
If anything the robos are more reliable since the heat sink for the
transistors is bigger and isolated from the rest of the power supply.
Mark Spaeth mspaeth@mtl.mit.edu
50 Vassar St., #38.265 mspaeth@mit.edu
Cambridge, MA 02139
(617) 452-2354 http://rgvac.978.org/~mspaeth
I've always had problems with the +5 volts on the ones i've had.
They don't put out enough, so the game keeps resetting.
After a switcher is installed, no problems.
Troy,
Mark C. Spaeth <mspaeth@plancherel.mit.edu> wrote in message
news:42583485$0$564$b45e6eb0@senator-bedfellow.mit.edu...
> What?
> Cambridge, MA 02139
: I've always had problems with the +5 volts on the ones i've had.
: They don't put out enough, so the game keeps resetting.
: After a switcher is installed, no problems.
IIRC, the PS is good for 10A... if the voltage is low, you just need
to tweak the ua723 reference...
Cambridge, MA 02139
What did you mean Tweak?
adjust the pot? didn't help with mine.
I don't own my robo anymore so I can't go look at it.
Troy,
:> IIRC, the PS is good for 10A... if the voltage is low, you just need
:> to tweak the ua723 reference...
: What did you mean Tweak?
: adjust the pot? didn't help with mine.
: I don't own my robo anymore so I can't go look at it.
There is no pot... unless you put one on :)
Cambridge, MA 02139
> John
A good working linear (original) will outlast a switcher 2-3 times or more.
Rebuild.
