Williams Tri-Zone sound problem
G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
My William's Tri-Zone has sound for about the first minute of play and
then it goes out. I've swapped in known working sound and power boards
and the same problem is repeated. I've checked all the connections and
they seem to be fine... any other suggestions for something I'm
missing? Thanks! --Dan
G
Guest
Guest
Several things can cause this in these old games- here's some things to
check:
- Look for cracked solder joints on the backs of the connector pins on the
driver board- lower left connector. Re-flow with fresh solder. This
connector is where the "signals" go out to the sound board, telling it to
make noise. Remove the board and inspect for cracked joints. While you're
in there, check for cracked joints on any/all of the other connector pins on
the back of the board. This is probably the #1 problem with reliability and
intermittent problems in these old games- just an old-age problem that
should always be addressed when going through/overhauling your game.
- Check for the same on the back of the sound board. Also can't hurt to do
this on all the boards in your game- if you find one board with cracked
joints, you will find others.
- Volume control knob on the sound board is a common failure part, but if
you've swapped in other boards and had same problem/symptoms, then most
likely this isn't the case. But old volume pots can develop "dead" spots on
the wiper contacts inside and cause sound to cut out intermittently.
Sometimes spinning them back/forth repeatedly can help clean up connections,
but if problem persists, you may have to replace the pot.
- Check the voltage at your wall plug. If it is high (over 117vac) then the
CPU chip on the sound board could be running hot as a result and
"overheating" - making the board lock up. This is a problem more commonly
seen on later model Wms games (up to 1983) but may be possible in the older
ones too.
Hope that helps!
Ray J.
Action Pinball & Amusement, LLC
Salt Lake City, Utah USA
Web: www.actionpinball.com
We're serious about pinball. Anything else is just for fun!
G
Guest
Guest
my first thought was the volume pot also. does it have one in the cab?
does the second board stay on in another game? maybe same problem on both?
Timathie
"Ray Johnson - Action Pinball" <staff@actionpinball.com> wrote in message
news:-tadnStMxruNLr3eRVn-gw@aros.net...
> check:
> you're
> on
> and
> do
> on
> connections,
> the
> older
> ones too.
> Hope that helps!
> Ray J.
