Hi folks. I have a self-built desktop PC that is running Win 7 64 bit. It's a fairly bare bones setup as I only use it for gaming, some Internet browsing and occasional work using Microsoft Office. I've been running a 250 GB HD for a while now and everything has been working just fine. Until this morning of course.
My typical routine is to game at night for a few hours, sleep the PC while I go to sleep, then repeat the process after I get home from work. I reboot the PC probably once a week or so. This morning, when I went to wake the PC up to check something online it Posted, then immediately went to the Disk Read Error message. Ctr/Alt/Del, as you can imagine, just brought me back to the same screen after a failed boot. Again, everything has been working fine on it, including last night - no issues at all that would lead me to believe something might be wrong.
When it does Post, I have options to change the boot order or go into Bios, but F8 does not work to give me a safe start option. It does seem to recognize the HD though, as well as my DVD drive as those are the only two options in the boot menu.
I tired restarting it a couple of times to see if I could luck out with a boot, but all attempts came back to the disk error screen. Except one that is. On one of my tires it hung for a second after the Post screen, then the "resuming Windows" screen popped up like it was about to start normally. I celebrated too early though as it froze on that screen and didn't go anywhere. I restarted the PC and have not been able to reproduce this occurrence.
So, what are we thinking here, bad HD? I'm about to go into the weekend without my gaming fix available and I'm starting to panic on what to do. Thanks for any help you all can offer.
