If 65% resources free is all you get after all background task have been ended, then no this is not acceptable. This is only a hunch; try updating all your hardware drivers (video, sound, directx <i>but avoid directx 8.1</i>, mouse...etc.), check Microsoft's Knowledge Base for your symptoms, check for any recommended patches.
Just a suspicion I have for recommending the above, could be a result of memory leakage from poorly coded or buggy software. At least it is something that would help for the time being, until possibly I can discover something as I research. I'll post again if I find a probable cause.
Microsoft article on <A HREF="http://support.microsoft.com/support/kb/articles/Q259/1/61.ASP?LN=EN-US&SD=gn&FR=0&qry=slow%20windows&rnk=8&src=DHCS_MSPSS_gn_SRCH&SPR=W98SE" target="_new">Memory Leakage</A> so it could be a program that your recently loaded that after opening or closing could be causing the problem. But I'm still looking.
JC-------<*){{{>{~~~~~
Fisher of men<P ID="edit"><FONT SIZE=-1><EM>Edited by jc14all on 09/06/01 09:35 PM.</EM></FONT></P>
