WIn10 WD 2TB drive problem
Metapod
Commendable
Apr 11, 2017
18
Hi, I managed to installed Windows in a new drive (clean install) when booting from installation disk however bios cannot detect the drive and hence cannot load Windows although the installation is successful.
I tried docking the drive on other PC and it has the same issue bios cannot detect drive.
my setup:
Asus Gryphon Z87
Intel i7
Windows 10 Pro
WD blue 2T
Original thread, I was advice to post new thread here.
http://www.tomshardware.co.uk/answers/id-3385543/bios-detect-drive.html#xtor=EPR-8809
I installed the windows using DVD, window installation can detect the drive (I didn't check bios prior installation). Once the installation done and I try to boot from the disk nothing happen.
No error per se because it just directly directed me back to bios. The disk can be detected in Windows when I docked it on another PC.
You have to clean the drive before installing windows onto it.
Boot from windows installation media;
go to command prompt and execute:
  • diskpart
    list disk
    select disk x (x - number of your disk, should be 0, but make sure it's the right one)
    clean
    exit
And relaunch windows installation.
No adapter. The weird thing is if i connect my other drive with Windows (this drive is failing but windows can still boot) it can detect just fine.
I swapped around the cables and tested on different ports still the same problems.
