Win2000 won't start !!!!! / Need Help ............
DGP_2000
85
The error begins when the screen with the bar that runs along the bottom starts .
"Windows 2000 could not start because the following file is missing or corrupt : \WINNT\System\vgaoem.fon"
You can attempt to repair this file by starting Windows 2000 setup using the original setup floppy or cd rom.
Select "r" at the first screen to start repair .
Ok , first I don't have my copy of Win2000 at home . I left it at my parent's house when I was putting it on thier system .
I do have a Win NT version 4 disc & was wondering if that would work ?
Anything else I can do ? (luckily I do have a second computer to deal with problems like this . Very helpful .
"I do have a Win NT version 4 disc & was wondering if that would work ?"
Not likely. The setup files are different.
You have some floppy disks laying around? You'll need four.
Go here: <A HREF="http://www.topqualityfreeware.com/bootdisk.shtml" target="_new">http://www.topqualityfreeware.com/bootdisk.shtml</A>
You can download the boot disks from this site, and then use them to repair or replace the corrupted/missing file.
Toejam31
<font color=red>My Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new">http://www.anandtech.com/mysystemrig.html?rigid=6847</A>
______________________________________________________________
<font color=purple>"Procrastination on your part does not constitute an emergency on my part."</font color=purple>
Another great link from Toejam...great job, buddy! I'm gonna bookmark that one. :smile:
<A HREF="http://www.geocities.com/btvillarin" target="_new">My Website</A> - updated basically everyday.
Thanks!
That one was officially, Bookmark #1027, in folder 19.
LOL!
Toejam31
So if I use the four floppy method or have the Win2000 cd , it will more than likely fix/solve the problem ?
Thanks for all of your help :)
