G
Guest
Guest
Hey everyone, thanks for looking at my post. My initial problem was when I started my computer, it would freeze on the black screen when the "Starting Windows 2000" bar at the bottom of the screen would get 1/4 of the way across. I tried to boot in safe mode as well as all the other options that are shown when you press F8 but the same thing happens all the time.
I tried disconnecting all of the unecessary hardware and I've tried dissabling DMA mode but no luck. I used a NTFS DOS boot disk and can get around on my hard drive but win2k won't detect my hard disk as you will see beneath.
I have come to the point where I tried to repair and re-install win2k but when I use my win2k boot disks and I'm prompted to choose between repair or install, they both lead this this message:
"Setup did not find any hard disk drives installed in yur computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit setup, press F3"
My computer started freezing up for no reason, I hadn't installed any new hardware or software. I checked all my connections to and from the motherboard and everything checks out ok. My computer has been down for 2 weeks now and this board is my last hope... Here's what I'm running:
-Asus A7v Mobo
-800 mhz Thunderbird
-128mb Micron ram
-ATI radeon 64mb VIVO
-3com 905 network card
-soundblaster live! value
-45GB IBM DESKSTAR 75GXP
Thanks
<P ID="edit"><FONT SIZE=-1><EM>Edited by rsauve on 02/14/01 06:58 PM.</EM></FONT></P>
-Asus A7v Mobo
-128mb Micron ram
Thanks
