Win7 High Defenetion Audio Driver !!! HELP !!!
ahmed zizo
39
hello....i Want to install RealTek HD Audio Driver... I downloaded it and installed it then .... after rebooting i dont see the realtek driver at the Device Manager...i see only High Defenetion Audio which is Microsoft's one and i tried to unistall/Disable it and it get enabled again after rebooting...So i need help to Remove the microsoft's High defenetion audio driver and install the Realtek Audio driver..... hope you guys take a look at this
PC: G41m-combo
Intel core2quad q9400
Asus r7 250 1gb DDR5
4GB RAM
500GB HDD
yeah ty i wanted a powerful and good audio driver to fix my problems at bf3 so i wanted to get realtek to fix this problem in the game and i tried Via before didnt change anything
Just WHAT is it that you want from your sound? What leads you to believe a Realteak audio driver has anything to do with what you are looking for? Different sound cards use different sound processor chips manufactured by different companies and most of them use drivers which are specific to that model of sound card. An Asus sound card will use different drivers than a Creative Sound Blaster card(s) which will use a different driver from many other sound chips including Realtek which is a common sound chip shipped on motherboards with built in sound chips. What is the problem with your current sound? Not loud enough? Not enough bass, no equalizer, looking for Surround Sound, WHAT?
all i need is a Powerful sound card and driver to fix freeze problem in bf3
my problem is like this video : https://www.youtube.com/watch?v=XzS1LBQ2zsE
and the Solution to improve the Sound chip and driver iam using VIA Chip and Driver and its not Powerful enough to handle a game like BF3 so my cousin is using the same as my PC (Intel core2Quad/4GB RAM/Asus r7 250 1gb DDR5/) and he is using the Realtek Chip and Driver and the Game works Great for him
Newest VIA audio drivers.
http://www.via-drivers.com/download-VT1708S-sound-driver-for-Windows7-64bit.html
VIA HD Audio Codecs for VT1702S, VT1705, VT1708B, VT1708S, VT1716S, VT1718S, VT2010, VT2002P and VT2020S
The audio drivers provided on this website are general sound effect drivers with common functions. System manufacturers and motherboard vendors customize audio hardware and software and therefore, to ensure optimal sound quality and compatibility, we strongly recommend you to obtain the system-validated and certified audio drivers directly from your system manufacturer or motherboard manufacturer. If you use audio drivers provided on this website and you experience a difficulty, we recommend that you uninstall them and instead use the latest drivers supplied by your motherboard or system manufacturer.
Supported Windows XP (32/64bit), Windows Server 2003 (64bit), Windows Vista (32/64bit) and Windows 7 (32/64bit).
If you insist on getting a Realtek driven sound card how much money can you spend?
