Win7 Problem
tomekr1983
8
Hi. I have a problem with my PC. It self build PC:
asus p6t se
i7 920 DO
GTX 275 Palit
OCZ 1866 6GB
The problem is after installing Win7 64-bit i`ve got Appcrash on everything i downloaded and try to install...
On XP 64 bit it works properly.
Please help!
It sounds to me like your downloads are corrupted - you should look to see if the download site has a checksum for the download and then run a utility to ensure the checksum of your copy matches it.
Its when im trying to install any application downloaded from the internet. Opera, peazip, winamp, even drivers for the graphic card...
If im trying to install from a cd then its ok.
The exact message is🙁on everything)
Appcrash
Name of application
Its version
timestamp
Fault Module Name: its a name of application
Fault module timestamp::48c8b2ef
Exception COde:c0000005
Exception Offset:00002c86
Then its os version
Regional settings
Additional information:
5719
571995eaee3b9ac2ce50c508a35fbffa
a1d0
a1d00b6044ec7c2223ec378c0d3e0178
It could be the i7 920 intel cpu.
I have an AMD cpu w/ win7 64bit and winxp 64bit 32bit and all works great.
It might have to do with your intel cpu.
is your i7 920 latest revision? with x86 extension?
