Window 7 OR HDD PROBLEM ?
Danial isaac
49
Hye Tomshardware .. 😀
i got this problem while gaming (Crash/Freeze/sound loop/).. im using Window 7 but not genuine n im using removewat and my HDD is 300gb ... can can removewat make my game crash ?and can my HDD make game crash ? btw i already check my HDD using crystal disk and my hdd in good condition...
This is my spec:
Proc :i7 2600k
mobo:asrock h77 Pro4/mvp
ram:8gb kingston
hdd:300gb forgot what model
cooler:cryorig h7
gpu : sapphire hd 7950 3gb
Game that always crash :
apb reloaded and CSGO
I know that y i asking here.... if removewat cause game crash or bring others problem to pc i will use genuine window 7 -,-
non genuine could have been modified to contain anything--keyloggers,trojans etc
use genuine windows
Hi
First remove any over clocking
Next check for clogged CPU heat sink & fan and any filters which may cause over heating
I suggest you boot from a ram test boot disk such as memtest86 to test ram
Then boot from a bootable hard disk diagnostics program
Look ad Hirens boot for both ram & HDD diagnostics
This will see if you have any hardware problems which need to be fixed
If not consider a fresh legal install of windows
Regards
Mike Barnes
