Did you buy the computer that way or did you build it?
If you can get a hold of a Windows 7 Ultimate 64-bit disc, you can use the "upgrade" option during install then use your current Windows 7 Ultimate Key on the side of your computer. If you can't, you may have to shell out the 200 bucks for a Windows 7 Ultimate Upgrade, which will come with a new license and 32/64 bit discs.
