Windows 10 Problem With Display/Location of Pop-Up Dialog Boxes
In every earlier version of Windows that I’ve used, when a Windows Dialog Box is generated (such as to do this, are you sure you want to do this, select an option or location, etc.), that Dialog Box appears ON TOP of the underlying screen and thus immediately visible to act upon.
Under Windows 10, I’m finding that pop-up dialogs that need to be acted upon do not necessarily appear ON TOP of the underlying screen. The dialog box may be underneath other Windows and thus I do not know it’s there unless I suspect there should be a dialog box and go hunt for it.
I suspected this problem was a matter to be resolved using the “Files and Folders” function/preferences, but I cannot find the solution.
Can anyone suggest a solution?
Thank you.
Thank you.
