Windows 7 Only Starting Only After Initial Power Off
Hey Tom's Hardware folks,
I've recently upgraded my computer with a second GTX 780 and a few new hard drives and did a clean install of Windows 7. My setup is now as follows:
-Corsair Carbide 500R
-ASUS Z87 Pro
-i5-4670K
-EVGA Superclocked GTX 780 3GB
-Corsair HX850 850w
-Corsair Vengeance LP 16GB (2 x 8GB)
-Cooler Master Hyper 212 EVO
-Samsung 840 EVO 120GB
-Samsung 840 EVO 250GB
-Seagate Barracuda ST2000DM001 2TB
-Seagate Barracuda ST4000DM000 4TB
-LG 12x BD-ROM
-4 x Rosewill 140mm fans
What I'm encountering however is that whenever I turn my computer on, it will start up and show the ASUS BIOS screen that always loads before Windows 7. It will then proceed to and act as though it's loading Windows 7, but then after a second, my monitor will act as if it's not plugged into anything and the display will darken. I know that it's not a matter of Windows 7 loading and the display simply not showing as when I turn on my XBox 360 controller, the flashing lights on the controller show that it's searching for a connection. If Windows 7 is up and running, the XBox 360 controller connects almost immediately. If I power off my computer and then turn it back on though, it then proceeds to load Windows 7 normally with seemingly no issues.
I know that as this started happening, I was in the process of doing a basic overclock to my CPU so I was in and out of the BIOS quite a bit, however I don't believe I changed anything other than the core ratios necessary to do my overclocking. I'm wondering if I'm missing some sort of a setting in my BIOS or if there's something more severe that's wrong with the hardware setup. This issue seems to occur every time I turn my computer on, and seems to behave just fine the second time I turn on the computer. Has this issue happened to anyone else at all?
Thanks in advance for everyone's help. Any information you may have would be much appreciated. Thanks
Brian
-ASUS Z87 Pro
-i5-4670K
-Corsair HX850 850w
-LG 12x BD-ROM
Brian
