[SOLVED] Windows 7 PC very slow after replacing 32-bit hard drive with 64-bit hard drive
kilo24
83
It's a factory-reset hard drive from my grandmother's old computer. Uninstalled Norton which worked until I moved it to this PC, then I used Malwarebytes to remove six viruses, still slow at everything
Specs from Speccy:
Operating System-
Windows 7 Home Premium 64-bit SP1
Computer type: Desktop
Installation Date: 7/26/2019 6:19:51 PM
Serial Number: ------------------------------
Windows Security Center
User Account Control (UAC) Enabled
Notify level 2 - Default
Firewall Enabled
Windows Update
AutoUpdate Download Automatically and Install at Set Scheduled time
Schedule Frequency Every Day
Schedule Time 3:00 AM
Windows Defender
Windows Defender Disabled
Antivirus
Antivirus Enabled
Display Name Malwarebytes
Virus Signature Database Up to date
.NET Frameworks installed
v4.7 Full
v4.7 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Internet Explorer
Version 9.0.8112.16421
PowerShell
Version 2.0
Environment Variables
USERPROFILE C:\Users\Felix
SystemRoot C:\Windows
User Variables
Machine Variables
Power Profile
Active power scheme Balanced
Hibernation Enabled
Turn Off Monitor after: (On AC Power) 10 min
Turn Off Hard Disk after: (On AC Power) 15 min
Suspend after: (On AC Power) 20 min
Screen saver
CPU-
Intel Pentium D 925
Cores 2
Threads 2
Name Intel Pentium D 925
Code Name Presler
Package Socket 775 LGA
Technology 65nm
Specification Intel Pentium D CPU 3.00GHz
Family F
Extended Family F
Model 6
Extended Model 6
Stepping 4
Revision C1
Instructions MMX, SSE, SSE2, SSE3, Intel 64, NX
Virtualization Not supported
Hyperthreading Not supported
Fan Speed 1541 RPM
Bus Speed 200.1 MHz
Rated Bus Speed 800.2 MHz
Stock Core Speed 3000 MHz
Stock Bus Speed 200 MHz
Caches
L1 Data Cache Size 2 x 16 KBytes
L1 trace cache 2 x 12 Kµops
L2 Unified Cache Size 2 x 2048 KBytes
Cores
Core Speed Multiplier Bus Speed Rated Bus Speed Threads
Core 0 2400.7 MHz x 12.0 200.1 MHz 800.2 MHz APIC ID: 0
Core 1 2400.7 MHz x 12.0 200.1 MHz 800.2 MHz APIC ID: 1
Total memory slots 4
Used memory slots 2
Free memory slots 2
Memory
Type DDR2
Size 2048 MBytes
Channels # Dual
DRAM Frequency 333.3 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 15 clocks
Bank Cycle Time (tRC) 21 clocks
Physical Memory
Memory Usage 84 %
Total Physical 2.00 GB
Available Physical 325 MB
Total Virtual 4.00 GB
Available Virtual 885 MB
SPD
Number Of SPD Modules 2
Slot #1
Type DDR2
Size 1024 MBytes
Manufacturer Nanya Technology
Max Bandwidth PC2-5300 (333 MHz)
Part Number M2Y1G64TU8HB0B-3C
Serial Number 2547458561
Week/year 33 / 07
Timing table
Frequency CAS# Latency RAS# To CAS# RAS# Precharge tRAS tRC Voltage
JEDEC #1 200.0 MHz 3.0 3 3 9 12 1.800 V
JEDEC #2 266.7 MHz 4.0 4 4 12 16 1.800 V
JEDEC #3 333.3 MHz 5.0 5 5 15 20 1.800 V
Slot #2
Type DDR2
Size 1024 MBytes
Serial Number 1289036291
Week/year 33 / 07
Timing table
Motherboard-
Manufacturer ASUSTek Computer INC.
Model LEUCITE3 (Socket 775)
Version 2.00
Chipset Vendor Intel
Chipset Model i945P/PL/G/GZ
Chipset Revision A2
Southbridge Vendor Intel
Southbridge Model 82801GB (ICH7/R)
Southbridge Revision A1
System Temperature 40 °C
BIOS
Brand Phoenix Technologies LTD
Version 3.16
Date 8/11/2006
Voltage
+5VTR 5.130 V
CPU CORE 1.224 V
ATX +3.3V 3.401 V
ATX +5V 5.078 V
ATX +12V 12.235 V
PCI Data
Slot PCI
Slot Type PCI
Slot Usage Available
Bus Width 32 bit
Slot Designation PCI1
Characteristics 5V, PME
Slot Number 0
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI2
Slot Number 1
Slot PCI
Slot Type PCI
Slot Usage In Use
Bus Width 32 bit
Slot Designation PCI3
Slot Number 2
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI4
Slot Number 3
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI5
Slot Number 4
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Designation PCIEX16
Slot Number 5
Graphics-
Monitor
ATI Standard VGA Graphics Adapter
Manufacturer ATI
Model Standard VGA Graphics Adapter
GPU Turks
Device ID 1002-6759
Subvendor MSI (1462)
Current Performance Level Level 0
Die Size 118 mm²
Release Date Apr 19, 2011
DirectX Support 11.0
DirectX Shader Model 5.0
OpenGL Support 4.2
Driver version 6.1.7600.16385
BIOS Version 01.00
ROPs 32
Shaders 480 unified
Memory 16 MB
Count of performance levels : 1
Level 1 - "Perf Level 0"
Storage-
Hard drives
Hitachi HDS721010CLA630
Manufacturer Hitachi
Product Family Deskstar
Series Prefix Standard
Model Capacity For This Specific Drive 100GB
Heads 16
Cylinders 121,601
Tracks 31,008,255
Sectors 1,953,520,065
SATA type SATA-III 6.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
Serial Number JP2940N03PMHBV
Firmware Version Number JP4OA41A
LBA Size 48-bit LBA
Power On Count 20652 times
Power On Time 982.0 days
Speed 7200 RPM
Features S.M.A.R.T., NCQ
Max. Transfer Mode SATA III 6.0Gb/s
Used Transfer Mode SATA II 3.0Gb/s
Interface SATA
Capacity 931 GB
Real size 1,000,204,886,016 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 35 °C
Temperature Range OK (less than 50 °C)
S.M.A.R.T attributes
Attribute name Real value Current Worst Threshold Raw Value Status
01 Read Error Rate 0 100 68 16 0000000000 Good
02 Throughput Performance 94 136 100 54 000000005E Good
03 Spin-Up Time 19595581 ms 123 100 24 00012B013D Good
04 Start/Stop Count 20,667 95 95 0 00000050BB Good
05 Reallocated Sectors Count 65,537 100 100 5 0000010001 Good
07 Seek Error Rate 0 100 100 67 0000000000 Good
08 Seek Time Performance 28 144 100 20 000000001C Good
09 Power-On Hours (POH) 982d 1h 97 97 0 0000005C11 Good
0A Spin Retry Count 0 100 100 60 0000000000 Good
0C Device Power Cycle Count 20,652 95 95 0 00000050AC Good
B7 SATA Downshift Error Count 0 100 100 0 0000000000 Good
B8 End-to-End error / IOEDC 0 100 100 97 0000000000 Good
B9 Head Stability 65,535 100 100 0 000000FFFF Good
BB Reported Uncorrectable Errors 24 76 76 0 0000000018 Good
BC Command Timeout 1,486,497,103 100 1 0 00589A254F Good
BD High Fly Writes (WDC) 0 100 100 0 0000000000 Good
BE Temperature Difference from 100 35 °C 65 57 0 0021230023 Good
C0 Power-off Retract Count 20,667 83 83 0 00000050BB Good
C1 Load/Unload Cycle Count 20,667 83 83 0 00000050BB Good
C2 Temperature 35 °C 171 139 0 0000120023 Good
C4 Reallocation Event Count 1 100 100 0 0000000001 Good
C5 Current Pending Sector Count 2 100 100 0 0000000002 Good
C6 Uncorrectable Sector Count 0 100 100 0 0000000000 Good
C7 UltraDMA CRC Error Count 48 200 199 0 0000000030 Good
Partition 0
Partition ID Disk #0, Partition #0
File System NTFS
Volume Serial Number 9E750C14
Size 99 MB
Used Space 29.6 MB (29%)
Free Space 70 MB (71%)
Partition 1
Partition ID Disk #0, Partition #1
Disk Letter C:
File System NTFS
Volume Serial Number A07B6846
Size 916 GB
Used Space 27.8 GB (3%)
Free Space 888 GB (97%)
Partition 2
Partition ID Disk #0, Partition #2
Disk Letter D:
File System NTFS
Volume Serial Number DCA28812
Size 14.8 GB
Used Space 13 GB (87%)
Free Space 1.84 GB (13%)
Optical Drives-
TSSTcorp CD/DVDW TS-H652L ATA Device
Media Type DVD Writer
Name TSSTcorp CD/DVDW TS-H652L ATA Device
Availability Running/Full Power
Capabilities Random Access, Supports Writing, Supports Removable Media
Read capabilities CD-R, CD-RW, CD-ROM, DVD-RAM, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
Write capabilities CD-R, CD-RW, DVD-RAM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
Config Manager Error Code Device is working properly
Config Manager User Config FALSE
Drive E:
Media Loaded FALSE
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 1
SCSI Target Id 0
Audio-
Sound Cards
High Definition Audio Device
USB Audio Device
Playback Device
Speakers (USB Audio Device)
Recording Device
Microphone (USB Audio Device)
Peripherals
HID Keyboard Device
Device Kind Keyboard
Device Name HID Keyboard Device
Vendor Primax Electronics
Location USB Input Device
Driver
HID-compliant mouse
Device Kind Mouse
Device Name HID-compliant mouse
Driver
USB Audio Device
Device Kind Audio device
Device Name USB Audio Device
Vendor C-Media Electronics Inc
Comment USB Audio Device
Location 0000.001d.0000.001.000.000.000.000.000
Driver
USB SD Reader
Device Kind Portable Device
Device Name USB SD Reader
Vendor GENERIC
Comment F:\
Location UMBus Enumerator
Driver
USB SM Reader
Device Name USB SM Reader
Vendor GENERIC
Comment H:\
Driver
USB CF Reader
Device Name USB CF Reader
Vendor GENERIC
Comment G:\
Driver
USB MS Reader
Device Name USB MS Reader
Vendor GENERIC
Comment I:\
Driver
Printers
Fax
Printer Port SHRFAX:
Print Processor winprint
Availability Always
Priority 1
Duplex None
Print Quality 200 * 200 dpi Monochrome
Status Unknown
Driver
Microsoft XPS Document Writer
Printer Port XPSPort:
Availability Always
Priority 1
Duplex None
Print Quality 600 * 600 dpi Color
Status Unknown
Driver
PDF Complete (Default Printer)
Printer Port PDFC
Availability Always
Priority 1
Duplex None
Print Quality 300 * 300 dpi Color
Status Unknown
Driver
Driver Name PDF Complete Converter (v1.00)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\pdfc_core.dll
Network-
You are connected to the internet
Connected through Intel PRO/100 VE Network Connection
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Wi-Fi not enabled
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout (ms) 60,000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout (ms) 30,000
IEProxy Auto Detect No
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Sharing and Discovery
Network Discovery Enabled
File and Printer Sharing Enabled
File and printer sharing service Enabled
Simple File Sharing Enabled
Administrative Shares Enabled
Network access: Sharing and security model for local accounts Classic - local users authenticate as themselves
Network Shares
Users C:\Users
Current TCP Connections
C:\Program Files (x86)\Dropbox\Client\Dropbox.exe (2592)
C:\Users\Felix\AppData\Local\Discord\app-0.0.305\Discord.exe (5440)
C:\Users\Felix\AppData\Local\Discord\app-0.0.305\Discord.exe (6044)
lsass.exe (496)
MBAMService.exe (1836)
services.exe (480)
svchost.exe (732)
svchost.exe (844)
svchost.exe (932)
System Process
UNS.exe (4036)
wininit.exe (432)
wmpnetwk.exe (3364)
I am surprised it even runs at all. not even a factory reset will work because the drivers would be for another computer. Your only bet is to try to install Windows 10 with the Media Creation tool to do the upgrade.. PRAY that that works and you get the free upgrade. then at that point, do a Complete Restore of Windows 10.
