Question Windows's system sound mutes itself.
Davoda1
35
As the title says the system's sound mutes itself and even if I unmute it manually in the sound mixer it mutes itself again.
If there is any kind of fix I'd be happy to hear it.
cbX3bcF
What windows 10 are you using? Is it the latest update?
Sorry about it, I'm annoyed and tired so yes... info is missing.
So here is what I think is relevant; probably I missed out thing so I'll try to add them if needed.
Windows 10 Pro 64bit latest update (Feb. 07.) Build: 19042.985
I use multiple audio output and I switch between them (the issue always happens when I switch; but even when I don't it happens as well)
All drivers are up-to-date (windows audio drivers, realtek audio, etc.)
I have tried every "fix" I could find that is at least remotely similar to mine. (re-install driver, restart in safe mode and so on)
Troubleshooter did not give any errors.
It happens with any audio device I try; no matter the type of connection it has (HDMI, USB, 3.5mm audio, DVI)
MS support doesn't even work for me for... some reason so that is a luft.
1 thing I thought could be the problem was the "Focus assist" but it is turned off completely, at least that is what it wants you to think.
P.S.: Sometimes that it's muted only shows up when there would be something to make a sound (line when you change the volume on the taskbar), before that it shows as having sound. I don't know if it makes sense.
