[SOLVED] Winload.efi error after enabling Fastboot
mustafaiq
Commendable
Feb 5, 2018
5
Hello
I have an Asus B360 Tuf Pro Gaming Motherboard
With Windows 10 Pro
When i trying to enable the fast boot feature in bios
Windows shows a Winload.efi error missing or corrupted
But when i disable it , Windows start normally without any Problem ??!
So what's the Issue here? is there any solution?
Thanks
Hello mustafaiq,
Fastboot has lots of problems and I would advise you not to turn it on. Although, if you want to take the risk, you need to enable fast startup in the Control Panel then enable fastboot. If this doesn't work, reinstall Windows with Fastboot enabled.
Hello mustafaiq,
