G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have an A7N8X-E board with WinXP on an IDE drive. I installed a SATA
drive, already partitioned and formatted, to be used for data, but XP
won't see it. The SATA HD shows up on the screen during boot, right after
the lines about the SATA driver for RAID, Also, I loaded Fdisk from a
Win98 boot diskette, and it sees the SATA drive properly.
In the process of trying "everything" I added added a third HD with
Win98SE on it, booted that, and, lo and behold, Win98 *does* recognize the
SATA drive right off the bat, reads the files on it, and sees it as a
normal drive in every way. XP sees the Win98 drive normally, but not the
SATA drive. Should I just scratch XP and go back to Win98... [lol]
I'd be very grateful for any suggestion or ides. Thank you!
