My current set up…
Router on ground floor (room GF1).
Pc in first floor room (room FF1).
Printer in first floor room (room FF2).
The pc has always been hard wired to the router with a cat5 cable, as mother board doesn’t have wi-fi and have wanted max speed.
I don’t have great wireless reception in any of the upper floor rooms, so a while back I purchased a set of wireless home plugs adapters, to get wireless connectivity for my printer and phone etc on upper floor rooms.
The pc is still hardwired with the original cat5, because when I tried to connect it to the home plug adapter (via a cable to bottom of home plug) it only ran at half the speed.
I use the upper floor home plugs for my phone and printer connection etc.
There are other random devices at ground floor that connect wirelessly to the main router (now tv stick, phones, laptop etc).
The main home plug adapter is connected to the router in GF1. The other 2 adapters are in each of the first floor rooms.
What I would like advice with…
I recently purchased an oculus quest 2. I would like to connect my oculus to my pc wirelessly with a fast reliable connection (I already own the oculus link cable, but want to try wireless).
From what I can find on the internet, my understanding is the best way to do this is to have a wireless access point in room FF1 that my pc and quest can connect to. I believe the oculus has wifi 6?, and I should use a 5g connection.
Does this mean if I purchase a wifi 6 spec access point with ports on the back, I can simply plug the access point in to the cat5 cable (connected directly to my router), then plug my pc in to a port on the back of the access point, and my pc will communicate directly with the oculus quest.
Will the access point provide me with a direct connection from my pc to the oculus via wi-fi, or will the access point still send info to router and then back to the pc (or if it does, is it relevant).
I guess I’m asking if this is the most optimal / fastest way to connect the pc to the oculus in my situation.
I’ve read that I can achieve a fast connection to my pc by putting my main router in to modem mode, then connect it to a new router in the upper floor rooms with cat5. However, I’m not sure that will work for me as I will lose the wireless connections downstairs.
Many thanks in advance for any advice / help you can provide me.
Ben
Ben
