• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Wired and Wireless networks are different (TPLINK N600)
orenl2007
Commendable
Nov 15, 2017
16
Hey, got very weird issues with my networking.
I have a TPLINK N600 router, which has wireless network name "roommates" (both on 2.4 and 5).
In the past I have linked extender to this router, going under the name "roommates_2.4_EXT".
Few days ago I have finally moved the router next to my PC, which allowed me to link Ethernet connection directly to my PC.
Now two weird issues came:
  1. A lot of online services stopped working while I have my ethernet connection - services like EA Origin, some VOD services and prob more.
  2. My network changed into roommates_2.4_EXT when I plug in the ethernet connection, although the extender is long gone few months ago. How it possible? seems like my computer treats the ethernet connection as different network than my wireless, and using the name it shouldn't know.
I'd like to avoid a factory reset to my router since I'm not fully sure I remember the ISP connections and its some serious pain in the a** to contact them and retrieve it again.
Any ideas on how can I resolve these two issues?
Ralston18
Check your computer. Ensure that only one network adapter (either wired or wireless as desired) is enabled.
On your computer run "ipconfig /flushdns" (without quotes) via the Command Prompt.
If the problem continues, run "ipconfig /all" via the Command Prompt and post the results.
The name does not really matter it is mircosoft being too smart for its own good. It many times does not know how you have connected to the network but sees the same IP or maybe the same router. I am unclear how it picks this name sometimes. It really is just a string of text and does not mean much.
Why origin does not work is something else. I would use the option to disable the firewall on your PC temporarily. Windows again is too smart and sometime it will decide your pc is on a public network and put in rules that pretty much only allow simple web surfing.
orenl2007
Commendable
Nov 15, 2017
16
Flipped my wired network to private as suggested in the 2nd comment, flushed DNS - not works.
What information should I hide when posting the ipconfig /all?
Nothing to hide as that's all internal network information and not public.
I suspect you set up your extension as another router with another subnet somehow so technically they would be two different networks. But with both normally going to the Internet I don't see how stuff just broke like that.
Ralston18
Yes: "ipconfig /all" can be very helpful - nothing to really hide there.....
I am always curious about the "world" as a computer sees it with respect to other devices and IP addresses.
Run and post the results of "arp -a" via the Command Prompt.
Reactions: SamirD
orenl2007
Commendable
Nov 15, 2017
16
ARP res:
Interface: 192.168.1.105 --- 0x3
Internet Address Physical Address Type
192.168.1.1 ec-08-6b-6a-83-bf dynamic
192.168.1.106 16-59-c0-34-5d-85 dynamic
192.168.1.108 8c-86-1e-d6-6a-d3 dynamic
192.168.1.255 ff-ff-ff-ff-ff-ff static
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
239.255.255.250 01-00-5e-7f-ff-fa static
255.255.255.255 ff-ff-ff-ff-ff-ff static
ipconfig /all:
Windows IP Configuration
Host Name . . . . . . . . . . . . : XXXXXXX
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V
Physical Address. . . . . . . . . : 30-9C-23-B8-BE-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 52-3E-AA-83-15-49
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 52-3E-AA-83-1D-49
DHCP Enabled. . . . . . . . . . . : No
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Broadcom 802.11ac Network Adapter
Physical Address. . . . . . . . . : 50-3E-AA-83-15-49
Link-local IPv6 Address . . . . . : fe80::a5db:c860:f749:b4b7%3(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.105(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, 13 July 2020 19:00:42
Lease Expires . . . . . . . . . . : Tuesday, 14 July 2020 21:29:39
Default Gateway . . . . . . . . . : fe80::90f0:80ff:fe54:b31a%3
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 357580458
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-3D-42-97-30-9C-23-B8-BE-15
DNS Servers . . . . . . . . . . . : 2606:4700:4700::1111
2606:4700:4700::1001
1.1.1.1
1.0.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-1A-7D-DA-71-15
Ralston18
Not noting anything astray via "arp -a" or "ipconfig /all".
You do have at least two other network devices using the DHCP IP addresses of 192.168.1.106 and192.168.1.108 - are there any other devices? Are you able to identify those two devices via IP address or MAC?
Is either one the extender? Make and model? How is the extender connected and configured?
Connectivity:
ISP ----> Modem ----ethernet cable --->[WAN] TP N600 [LAN] ---- ethernet cable ---> wired devices and
~~~~ wireless ~~~~ > wireless devices.
Make and model modem. Where is the extender?
Edit and correct my line diagram as necessary.
Run and post the results of "tracert 8.8.8.8"
orenl2007
Commendable
Nov 15, 2017
16
Connectivity:
Ok the instructions are bit confusing but ill try the best to answer:
1. other devices - I have xiaomi smart tv, LIFX smart bulbs, chromecast and laptops around
2. There indeed an extender - NETGEAR Nighthawk X6 functioning as access point on second floor. (linked through ethernet cable to TPLINK modem)
3. My PC connection is directly into the TPLINK, there is no middle hardware both in wired and wireless connections.
Diagram:
ISP ----> [WAN] TP N600 [Modem + LAN] ---- ethernet cable / wireless ---> My PC
trace results under wireless:
Code:
Tracing route to dns.google [8.8.8.8]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2    18 ms     9 ms     9 ms  bzq-79-177-64-1.red.bezeqint.net [79.177.64.1]
  3    10 ms    12 ms    11 ms  10.250.1.6
  4    61 ms     8 ms     9 ms  bzq-25-77-2.cust.bezeqint.net [212.25.77.2]
  5     *        *        *     Request timed out.
  6   127 ms   186 ms   133 ms  74.125.51.88
  7    47 ms    49 ms    53 ms  108.170.252.225
  8    47 ms    47 ms    47 ms  66.249.94.127
  9    46 ms    49 ms     *     dns.google [8.8.8.8]
10    49 ms    46 ms    46 ms  dns.google [8.8.8.8]
Trace complete.
trace results under ethernet:
Code:
  2    16 ms     9 ms     9 ms  bzq-79-177-64-1.red.bezeqint.net [79.177.64.1]
  3    13 ms    11 ms    12 ms  10.250.1.6
  4     7 ms     7 ms     7 ms  bzq-25-77-2.cust.bezeqint.net [212.25.77.2]
  5     7 ms     7 ms     7 ms  10.90.99.9
  6    45 ms    44 ms    45 ms  74.125.51.88
  7    46 ms    46 ms    46 ms  108.170.252.225
  8    46 ms    45 ms    46 ms  66.249.94.127
  9    45 ms    45 ms    45 ms  dns.google [8.8.8.8]
Trace complete.
Ralston18
What is the IP address on that second floor Netgear Nighthawk? How is the access point configured?
If I am understanding the network setup correctly that access point should have its DHCP disabled and have a static IP address assigned to the access point via the TP-Link router.
The assigned static IP address should be outside of the DHCP IP address range allowed to the TP-Link router and the static IP address should be reserved for the access point via the Access point's MAC.
I do not see any "192" static IP's in the arp -a results.
