Hi guys, so my wired connection isn't working on my desktop pc and I'm having a difficult time figuring out why. Here's the results of ipconfig /all and some pings:
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-E7EU8JH
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I218-V
Physical Address. . . . . . . . . : 78-24-AF-BE-FC-A0
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::f13c:f167:f443:37e5%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.13(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, August 4, 2018 6:12:20 PM
Lease Expires . . . . . . . . . . : Sunday, August 5, 2018 6:12:19 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 242754735
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-59-5E-2D-94-10-3E-1B-1B-81
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : TAP-Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-4F-71-90-96
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Linksys AE2500
Physical Address. . . . . . . . . : 94-10-3E-1B-1B-81
Pinging 127.1.1 Gives:
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Pinging 192.168.1.1 Gives:
C:\Users\TEMP>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.13: Destination host unreachable.
Ping statistics for 192.168.1.1:
My wireless is working fine on both my desktop and other devices. Not sure what the deal here is. It show it being connected but no internet. I've tried power cycling my router and modem. Using the troubleshooter will provide 1-3 errors like "the default gateway is not available"(the most common one) and say it fixes them and it will appear I have internet when looking at the indicator on the bottom right but it still won't work and then eventually it will go back to saying I have no internet and the process repeats. I've also made sure DHCP is active. The ethernet cord was recently hoked up to my ps4 and was working just fine so I don't think it's anything to do with that. And I forgot to mention I did flushdns and release and renew. Thanks in advance for any help!
Edit: Tried pinging google but it didn't work:
C:\Users\TEMP>ping google.com
Ping request could not find host google.com. Please check the name and try again.
Edit 2: I plugged the ethernet cable into my modem instead of my router and that gave my desktop connection but that means I have no wifi at all. I'd like to get it back into my modem because of that. Hopefully this edit helps a little.
