Wired connection slower than supposed to be
shaedyelnady
5
As of recently my wired connection has gone from downloading at a max speed of ~6,5 mb/s to 1,1 mb/s. I have not changed or touched anything. It happened overnight when I turned off my PC and I wonder what kind of issue it is and if i can fix it without replacing anything, also my network usage seems to be around 90-100% when around the 1.1mb/s download speed. Thanks in advance!
Sorry my mistake, I seem to be using DSL. Anyway I do not believe it is a fault with the Internet company due to the fact that the rest of the devices all have a 6,5 mb/s download speed. So I still wonder how to fix it.
What program/utility are you using to determine this? I assume you have 100Mbps or 1Gpbs lan ... 1Mbps is nowhere near 100% of what your hardware should be capable of doing.
I assume you are doing a speed test. When you do, you are testing everything between you and server hosting the test. To ensure the problem is on your end (ie, stuff you and your ISP can control), I would run tests from a couple other sites to ensure it's not a problem with the test site you tried.
