Wired Controller Issue
SphereUK
15
Hey guys
Whenever I try to plug my Xbox controller into my PC, the PC goes to a black screen with me just being able to control my cursor nothing else. Doesn't return to normal until i reset PC.
When i do the same with a Playstation controller, it gives me the same issue as soon as I load up DS4 Windows.
Ive uninstalled my XBOX controller drivers but to no avail.
Any help is appreciated, cheers.
what version of windows are you using? this is a known issue with the newer win 10 insider builds.
i use a wired XB1 controller myself with win 7 and win 10 with no problem but on the insider build it does exactly what you describe and no fix for it yet.
