[SOLVED] Wireles AutoService dot3svc.dll problem
techmail8888
4
Hey,
Iv found a problem that is giving me a hard time here. The service dot3svc.dll or Wireles AutoConfService is missing from my services.msc list. But there is the dll in system32 folder.
I tryed to restore it trough many ways yet none actually worked. Iv found answer on forums "Just input registry key from regidit from healthy pc to yours".
If anyone has idea or can send me a healthy registry entry i would be saved.
Forum where iv found registry soulution; https://social.technet.microsoft.co...autoconfig-service-missing?forum=winserverNAP
Stay away from the Registry. That is a very last resort effort and should only be used if you are confident that you can fully restore/recover your computer if the editing effort goes astray. Likely.
[Note: that link was very slow to come up and the "solution" is 7 years old.]
Suggestions/other options:
1)Try running the built-in Windows' troubleshooters - they may find and fix something.
2) Download the applicable wireless network adapter drivers via the manufacturer's website.
Reinstall and reconfigure for your router and network.
3) From the command prompt run "sfc /scannow" (without quotes) - Windows may find and fix problem in that manner.
Reference...
Reference:
https://www.lifewire.com/how-to-use-sfc-scannow-to-repair-windows-system-files-2626161
