Wireless Access Point With Ethernet Ports?
Sep 2, 2018
Hi, I have a Router in my main building which is obviously wired from my ISP. Then i have a Ethernet cable running from a port on my router to my outhouse (separate building), I need an access point for my outhouse that has Ethernet ports so I can wire my PC and Xbox to it as they both detect double NAT. Can anyone recommend a wireless access point that will work? If anything is unclear just ask me, sorry I’m a bit of a beginner :)
Any common router will do this.
You dumb down the 'router' functionality to be an Access Point. And this also leaves the 4 LAN ports on it.
Thusly:
http://www.tomshardware.com/forum/36406-43-convert-wireless-router-wireless-access-point
Thusly:
