Wireless Access Point with Ethernet Switch
bsam
I have a modem/router upstairs although get very weak / no signal in some places downstairs. I currently have a long ethernet run from the router upstairs to a PC downstairs.
I'm looking for a wireless access point that will take the internet from the ethernet downstairs to share wirelessly, although also need it to have a port to then still connect to the pc which does not have a wireless card.
Does such a device exist or will I need to connect the ethernet to an ethernet switch and then on to a wireless access point?
Thanks for any help!
Any decent router will do. Give the LAN side a static IP, disable DHCP, DNS, Firewall, UPNP etc etc and then connect them via a LAN port, to use it as a switch and wireless AP.
Pretty much any router will work. Do not spends lots of money for extra features many do not work when you run it as a AP. The router does not need a setting to run as a AP pretty much any will work. There is a sticky on this forum on how to use a router as a AP and there are even youtube videos......but it is really easy.
