Wireless Adapter (PCI TP-LINK TL-WN751ND v2)
Skyren
31
I've deleted some values in registry under this path. It cause many problems, like instant freeze after OS being loaded or not working safe mode with neworking... all this because of Wireless Adapter being plugged.
After it has been unplugged, everything started to work fine again. I was expriencing issues with installing my drivers for an adapter since Windows 10 is not compatitible with such adapters... so I had to change compatibility to Windows 7 and it went fine until it showed up another warning. I was confused so I did check the PCI itself. It was put correcty but didn't work. I even switched to another slot, but same result. Status LED is showing no activity at all, like MB is ignoring it.
I made conclusion it cannot be by faulty HW since it was working properly until the deletion of registry values.
Now, most of the folders are empty and I lack of Local Area Connection/Wireless.
Is there any expert into the registry that could help me out?
I really don't wanna reinstall nor anything similar.
Would be really gladful! :)
Thats the only prob with their adapters. Most of them dont have Win10 drivers
The adapter here WDN3200 doesnt have Win10 drivers either (until Win10 AU came out). Windows 10 the previous versions installed drivers, but the 5 GHZ connection didnt work.
Even tho this is an unofficial site these may work. Uninstall what you installed, if it installed anything
Here
64 bit
Get the 32 or 64 bit driver extract it. Then go to the device in device manager / dbl click on it / driver tab / update driver / browse /let me pick / have disk
Go to the extracted folder. Load the inf file
It shows blank list...
I tried this with official ones before advice, either blank list.
I think it's cause of registry, not the driver, but it can be also related.
Will Update help me? Will it fix the registry issues? Currently having 10586 build, while 14393 is being offered by Windows 10 Update Assistant. The reason I turned off Windows Update service is because I don't have enough of space for it. I am willing to free some space (25 GB), if there is guarantee of fixing it.
Well you wont know if it works till you try.
Whats blank?? When you go to have disk then go to the file you extracted? Works fine here. You have to go to the extracted folder with the driver in it
It brings up a window with Gigabyte and Qualcomm. You have to select Qualcomm, then select Qualcomm AR9227 in the right window
If youre running out of space, I would get a bigger hdd
Probably. I do CClean sometimes and I do backup it's registry, but no such path included. I deleted most of the sub-Network entries (first post) and they're blank now. I don't remember exactly, but they were named Local Area Connection/Wireless #2 - #12 or so, one VPN as well. I did so because the adapter was named #2.
I made 9 GB spare of 8 GB required so let it work and I'll let you know.
Well I definitely won't do that, at least not for now. It can work by copying entries from different PC?
I have only few values in Network, whereas others have much more.
PATH: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Network
PATH: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network
